Hide Arrow Control For Family
3 REPLIES 3
1424 Views, 3 Replies
Within the elevation tag there is a Control Symbol represented that is a tick box. When you hover over the box, it is called a Hide Arrow.
Can I use the Hide Arrow for families I have created myself?
I want the user to be able to click on a door family and for a number of these Hide Arrow Control Symbols to appear, giving them the option to turn on linework in and around the door showing access requirements
Thanks in Advance.
3 REPLIES 3
AJA14
You can do this using visibility parameters that act as instance or type yes/no parameters.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Yep, I know. But I don't want the user to control visibility in the properties box, I want them to do it on screen.
aghis_no
No there in no graphical control for family parameters other than the "flip controls".
However, there is an add-in from AutoDesk that you can download called "Parametric Sliders" that lets you control graphicaly parameters with on canvas sliders. I have never used it so I cannot tell you more. Keep in mind that it is designed for Vasari, so it might work in revit but I do not know it what extend.
Hope it helps
Aghis
