Hello All;
I have created a group (kitchen) & there is a half wall under the counter. I used the "show hidden line" process & that worked fine. But when I make the kitchen into a group, the hidden lines are not there. SO I tried the same process again, in the group editor, but I am unable to. I select the counter, then the wall I want hidden, but the linework will not allow me to change the lines to dashed.
It works when I insert/ copy the groups in the view, but I have change each instance, which there are a alot of them. Can't this be done in the group editor once & then all the copies will update?
So...?
Thanks in advance...
Jeff
You can create the lines as annotation in a attached detail group (which can also include the tags, dims, texts, etc.). Wouldn't be intelligent as with showing hidden lines, but would show on all your groups.
Gustavo
