Help with Help
1 REPLY 1
rtalbott
229 Views, 1 Reply
Help with Help
I keep getting error messages when I try to post a question.  One time it was (paraphrased) "text changed because of wrong HTML" another time it was "correct highlighted text".  There was no HTML or highlighted text in either case.  I couldn't post either message.
What am I doing wrong?
Thanks for hints
Richard
1 REPLY 1
loboarch
in reply to: rtalbott
The search function in the Web Help is not working properly.  You need to search the same string 2x to get a result.  Another way you may be able to find somethign without search is to use the index.  Many subjects can be found directly there.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Rail Community
