I have 3 visibility parameter: A, B, and AB.
I would like: AB = TRUE only when both A = TRUE and B = TRUE. What would the formula be like?
Solved by CoreyDaun. Go to Solution.
Use the AND function. Since the "A" and "B" Parameters are TRUE/FALSE, they can stand alone as a conditional statement. And since "AB" is a TRUE/FALSE Parameter, the formula need only be a conditional statement.
= And(A, B)
