Help with Formula
1 REPLY 1
221 Views, 1 Reply
Help with Formula
I have 3 visibility parameter: A, B, and AB.
I would like: AB = TRUE only when both A = TRUE and B = TRUE.  What would the formula be like?
1 REPLY 1
CoreyDaun
in reply to: ToanDN
Use the AND function. Since the "A" and "B" Parameters are TRUE/FALSE, they can stand alone as a conditional statement. And since "AB" is a TRUE/FALSE Parameter, the formula need only be a conditional statement.
= And(A, B)
