To copy an element from one option to another option in the same option set, select the element, Copy to Clipboard, start editing
the target option, Paste Aligned | Same Place. To move it from one option to another (or from an option to main model), do the same
but Cut instead of Copy.
I'm not sure what you mean about the element still being in the main model. No element should be in both the main model and in an
option. If it is then you should delete one or the other.
wrote in message news:4956251@discussion.autodesk.com...
We have some new personnel working with design options for store layout. In one option, the object appears, in another, it was
deleted, instead of being moved. How do you "undelete" that object in the second design option? It is still in the main model, but
cannot as far as I see, be removed from an option once it has been added to the option. This is an issue while scheduling the store
fixtures.
