Help/Suggestions for making a family
0 REPLIES 0
Message 1 of 1
tace86
178 Views, 0 Replies
Hi all,
I am fairly new to REVIT (using Revit Architecture 2013 - Windows7 64Bit) and was wondering if anyone has any suggestions to enable me to make a block with the following attributes/parameters.
Basically, we have a row of inground tanks, which need to be at the same invert level, however due to the slab falls on the site, the manhole openings are at different heights (and these change from site to site).  We were hoping to be able to make a block in which the manhole would automatically snap to the host height so that the "funnel's" down to the tanks are different heights.
We use this configuration for almost all of our sites and at the moment it is very time consuming to individually model each situation, and even more so when the site levels change constantly.
Does anyone have any idea if this can be achieved and if so, how is the best way to go around it?
Thanks in advance,
Stacey B
0 REPLIES 0
