I am not sure is this discussion is still going on but, after changing the folder propertiesfor Revit on Win 7
I still get the same error message with the: "please insert Disk....." when changing the material properties
to show render appearence.
Anyone else having the same problem or a solution for it besides pressing continue for about 20 times?
Thanks!
Thanks for your reply.
This is what is happening to my revit.
I got a new computer with Windows 7 -64 bit and installed revit 2010 on it, before that I was using windows X.
The problem is that I get a message : "There is no disk in the drive. Please insert a disk into drive \Device\Harddisk1\DR1" every time I go to the materials dialog box and click on "use render appearance for shading" (under graphics - shading).
If I click "continue" about 20 times it goes away but it is kind of annoying. I never had this problem before when I was using Windows XP.
I did what Brian said on this thread about setting "full control" on Revit folder, but that did not help. Any ideas are greatly appreciated.
Thanks!
I like to work on shade mode for 3d as it gives a better idea on how things will look once rendered. I heard
that Revit 2011 has the realistic view and it pretty much renders the 3d as it goes.
There is really no problem with the dialog, it is mostly an annoyance as it does not interfere with the rendering or
the visualization, it is just annoying to have to click on continue several times so it disappears.
Maybe I'll just have to live with it if there is really no solution as it seems to be a problem with Windows 7-64 bit.
Thanks for your help!
Oh boy, I know your pain. I know I'm posting this a year after the last post, but I"m having a similar issue. I have a registered 2010 version, but I added a student version on another computer so I could create renderings while I was working. Anyways, I moved a file that was opened in the student version onto my main computer. Now I have this error message whenever I try to modify materials in ANY of my files. Revit freezes up and I have to shut it down.
