hi..
I started to learn revit 2014 using the tutorial on youtube ... I noticed that the elevations is missing in the project browsing ...I want to know if there is any way to make them appear in the browsing by default? I uninstalled the program and reinstalled it but the same thing happend ... my friend had installed the same version from the same setup file and the elevations appeared already ... please help me .. thanx
Most likely, you are starting the projects without a template. Do: New > Project > change "None" for something such as "Architectural Template".
If you don't see a list of templates there, your installation of Revit is not a typical installation. Try to find the files with the Browse button. If not, try to repair the installation, or find the files (.rte extension).
thank you so much sir for your help ... but I just reintalled the program for the 4th time and same thing happened I can't figure out what's the wrong with it 😞 😞
don't reinstall. Just use control panel to "repair" your installation to add the content. more info here:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-851D6C9F-3E00-460D-B49E-341C22D3B9B5
