When I insert a window it sets the window at a SILL height. I would like to default inserting windows at a HEAD height. Can this be done?
Marc5
Solved by Alfredo_Medina. Go to Solution.
Revit does not really place the window at sill height. It shows 2 values that are related: sill and head. If you set the value of head height before placing the window, the sill value will adjust accordingly. Then the next window will have the same value for head height as default.
