I am getting an error when trying to install Revit Architecture 2014 Update Release 1. the error says it cannot locate the autodesk product on my computer.
I am getting the same error while trying to install Release 2 as well.
Solved by DarrenP. Go to Solution.
are you running revit architecture or revit? they are 2 separate products with 2 separate updates
DarrenP
I didnt think to consider that. my 2014 reads Autodesk Revit and my 2013 reads Revit Architecture
my coworker has same program loaded and he was able to load release 1 and release 2
for revit 2014 you need to install this update:
DarrenP
