Handrail Family Center
3 REPLIES 3
Camo335
372 Views, 3 Replies
I have created handrails in a project and they do not always appear in the elevations or sections. After much trial and error my coworkers and I discovered that the 'center' of the handrail family isn't anywhere near the handrail itself, about 800' away actually and if a view is not looking in the direction of that center the handrail is not visible.
I'm not sure that I'm using the correct terminology with 'center', but to be more specific the blue arrows used to flip the direction of the handrail.  When I select the handrail to move or copy it, the dashed selection box that encompasses the selection extends all the way out to this center as well.
The handrail itself is 'Handrail Type' that came preinstalled and I have no idea how to modify this or even if it CAN be modified.
Tags (1)
3 REPLIES 3
Alfredo_Medina
in reply to: Camo335
That is weird. No clue about that error. I've never seen the default railing type doing that.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Camo335
If anyone else stumbles across this, the problem was that I was creating a handrail without any balusters or other railing components which confuses Revit and it automatically places the handrail center at the model center. - Why would I do that?  Trying to create wall-rails.
Jason_S
Thank you for that information.  I have a similar issue and that helped me get mine fixed.
