My "Regular" baluster is really two posts spaced 2 5/8" apart. These balusters are 5 ft apart. I've got a "Corner" post family that is for the OUTSIDE corners. I also need to use a DIFFERENT family for inside corners.
I've got it to show the outside corner correctly but it wants to also show the regular baluster at the corner. And it's attempting to show the same outside corner post AND the regular post at the inside corners.
Can anyone offer any suggestions for this?
I've attached a revit file that includes my handrail and there is a screenshot below.
I left the corner posts gray so you could see them clearly. The wood looking posts are the "Regular" balusters.
TIA!
Don Ireland
Engineering Design Technician
Solved by constantin.stroescu. Go to Solution.
bump
Don Ireland
Try this if it works:
Constantin Stroescu
Sorry for the delayed reply. But I've been working on other things. I just now tried your suggestion (the first one -- didn't even try the second yet). And it seems to do a decent job of giving me what I need. Although the corners look good, the spacing between the regular posts is now 5' 5 243/256" and that's with the spacing set to 5' OR 6'.
EDIT: Option #2 looks like it'll work better. Instead of placing the corner post at the start as you suggested though, I'm placing it at the END. I really didn't want to see one at the start. Now I have none at the start, the regular ones show with the 5' spacing and then I have a corner post at the end of the rail (which is technically the corner). It just means that I have a bunch more handrails.
Don Ireland
