Gutter Cap ?
2 REPLIES 2
2559 Views, 2 Replies
Gutter Cap ?
My question is certainly quite simple but how can I model the end / cap of
my gutter and the same for my under-roof ?? (see the picture attached)
(Sorry for my bad English speaking)
Thanks in advance,
Stephane
2 REPLIES 2
Options are:
Generic Model for end cap. Use this if you want to see the cap in 3D.
Filled region if you just want to clean up the elevation.
Miter: Draw a model line alone the face of the rake. Use that as an edge to
pick to make a gutter return (don't have to pick just roof edges. Any edge
will do.)
In-Place Family. Use this if you want to cut the gutter with a void. I try
to minimize the use of in-place families as they can be messy.
"Stéphane" wrote in message
news:4997340@discussion.autodesk.com...
Thanks in advance,
Stephane
Thanks for Aaron for your reply, it helped me a lot ! ... but I still have
some questions :
- I used the generic model for end cap and it worked well (after drawing a
reference plane on an elevation)
- Gutter : I made a line on an elevation using the previous reference plane
and then tryed to add a gutter to close the void, but I get another void on
the other face ... How can I close that ?
Anyway I am afraid it will be a little bit long to draw all theses models,
faces, line on a big project. Too bad there isn't an "check box" to close
the gutter when creating it.
