I created a building section and all grid lines appear. I selected all grids that I want to appear in the building section, switched to 2D, and adjusted as desired. From that building section I created a callout for a stair section detail. In the callout view, some grid lines appear but not all grid lines appear. I turned off crop view but they still do not appear. Any help would be appreciated.
Please check the following:
2D extents of Grids
3D extents of Grids
Go to elevations and see if grids are maximized (Always create your levels first to avoid this problem)
Make sure nothing is hidden in the view.
Make sure the grids are orthogonal to your section otherwise they won't appear.
Hope this helps.
If it doesn't maybe you can post a picture for us to be able to help you further.
