Is there a way to make the grid line, label, dimension to look exactly the same? (including the locatiion of them)
I noticed when I shift the grid bubble little bit farther out, the other levels don't reflect this change. Why?
Thanks in advance.
Solved by David_W_Koch. Go to Solution.
Select one of your Grid or Level lines, and look for either "2D" or "3D" to appear near either end of the line. "2D" indicates that the extents of that line are controlled in just this view, and any edits will affect just this view. "3D" indicates that the line extents are linked to the overall model, and edits here will affect any other view that shows the "3D" extents. You can toggle from "3D" to "2D" by left clicking on the "3D". The drag grip will change from an open circle to a small, filled dot.
If you grip edit the extents of a line set to "2D", an open circle indicating the extents of the "3D" of that line will appear. Once dragged off of the "3D" circle, you will not be able to toggle that line back to "3D" until you drag the "2D" grip over and on top of that open circle. This Screencast has a quick video demonstrating this on a Level line.
