I do not recall making any changes to current settings and I'm not even sure how to do that.
All my new detail lines are green. I have to change them back to black using overides.
Does this signify something? How do I change the current color back to black?
AutoCAD 2010
AutoCAD 2015
Revit 2015
Solved by luna.ye. Go to Solution.
Hi kwg06516,
This is because the color of the detail lines' setting is green in the default template.
If you want to change the color of the lines, first, please check the line style of the green lines. Then on Manage tab, select “Line Styles” in “additional settings”. Please select the color button to change the color for which one you want to change.
Hop this helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
