No. That's the way it is designed. It is set up more to have a demo plan and
a new construction plan - not all 3 phases in one view.
However you can get it "faked" by setting up a couple of view. One will be a
wireframe with minimal information. See attached.
wrote in message news:4951173@discussion.autodesk.com...
I am having trouble with the graphics of demolished walls.
I find that if in the Phase Filter, I select "show all" so I can see my
existing walls, new walls and demolished walls, the demolished walls seem to
have a white fill in them. This means that when the demolished walls cross
other elements, they "blank out" the elements below them.
What I want to achieve are demolished walls whose outlines can cross other
walls or elements, but where I see those elements without the blanking out
effect.
Am I doing something wrong here?
Thanks!
