I've been given a new machine with quadro 400. It has a certified driver version for running with revt 2012 (I checked on the Adesk certified hardware page) but when I go to options, graphics it tells me-
The installed video card driver is newer than those certified by Revit.
Card: NVIDIA Quadro 4000; current driver: 8.17.12.7642
Certified drivers: 8.17.12.6570
You may continue to use Hardware Acceleration.
If you experience graphics display issues, you should:
- Turn off Hardware Acceleration; or
- Install driver that is recommended for use with Revit
Is there something I need to do to revit to get it to recognise I am actually running an Adesk certified driver?
Go to the NVIDIA driver site and download and install the
one Revit wants.
If you read somewhere that the 8.17.12.7642 is a certified driver,
go by what Revit tells you instead, use the 8.17.12.6570.
