In general, which updated drivers would you recommend to install - from Microsoft Update, from OEM or from the card manufacturer? For several of our systems, with different cards (NVIDIA and ATI), all certified for use with Revit, all of the above mentioned updates are available, with driver versions in different formats (Microsoft WDDAM X.X, OEM X.XX.XX.XXXX and card manufacturer XXX.XX) and close release dates.
Thank you.
Thank you for your post. In this case the recommended drivers for display systems can be found in the link below. Outside of this the preferred drivers from MS are the latest to ensure the systems are up to date with changes in the industry. I hope this helps.
System updates/Graphics updates: http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
