I have a serious display problem with Revit 2015, there is an unbelievable inaccuracy in the display of lines and points of Autocad imports. They seem to be shifting position as I zoom in and out and make it impossible to use them as background and survey and so on..
Anybody else has come across this problem? Any solutions available?
Solved by FinearcLtd. Go to Solution.
I have not seen this problem myself. Often difficult to find out what the problem is.
Could be a graphics card problem.
In Revit you could experiment with some/all of the "graphics mode" settings on the graphics tab of the options window.
You could look at updated graphics card drivers, Direct 3D versions.
It might also be that your graphics card is not compatible with Revit.
Further it might be memory problems.
Check if your hardware is compatible with the system requirements (LINK) of Revit.
Louis
Please mention Revit version, especially when uploading Revit files.
Thank you! Problem solved. Apparently this is caused by a survey dwg file that had elements too far out. The elements were deleted and the problem solved.
