You can turn off just the "rail" portion of the railings in the visibility
and graphics of the view. This of course will only work if this is the only
railing type in the view. If you have another railing type where you do
need to see "rails" this will not work.
Jeff Hanson
Autodesk - AEC Technical Publications
Manchester, NH
wrote in message news:5951092@discussion.autodesk.com...
I'm trying to build a structural glass guard rail that has no cap, based on
the attached manufacturer's section drawing. However, I cannot seem to
eliminate the top rail, because it defines the height of the baluster glass
panel.
I tried using a small top rail made out of glass as a workaround, but the
segments of 4'-0" glass panel are supposed to be separated by a 1/4" gap.
With railings running uninterrupted in Revit, it messes up the top.
Does anyone know how to remove the top ra
il without affecting the balluster? Thanks!
