Hi.
I have a little problem dispalying a custom Glass Block window family. It won't display when in plan view as it apparently doesn't get cut by the project cut plane. This is even when the center height of the window is exactly at cut plane height. All that shows is a blank area in the wall the size of the window when it should show the joints between glass blocks.
Any ideas, tips, hints are more than welcome.
Many thanks !
JF
