Revit Architecture
Active Member
mcfletch2015
Message 1 of 16 (481 Views)
Glass ball/concrete skin
481 Views, 15 Replies
04-15-2013 09:26 PM
Is there any way to replicate this skin of solid glass spheres hardened into concrete in the form of a panel of some sort?
That what you want is more typical for 3DS Max .....In Max this can be done both by 3d modeling - for instance using Box with Latice Modifier(or a other more sofisticated function) or by bitmap material maping.
Exporting 3d dwg from Max to Revit can be done , but in this case the model is too complicated,
If you want to do it in Revit , my opinion is that the only choice is to use material maping....
In order to achieve this task :
  • first create  in Photoshop a texture for the material ,one for Relief Pattern and one for Cutouts (in this case can be used the same map)
  • in Revit , select the object and apply a new material , it has to be a metal material because metal has Cutouts (a transparence filter) for example : Stainless steel <> Relief Pattern <>Cutouts ...apply the image created in Photoshop
I attached a render to see what can be done using this method....
A better method is to export the Revit file (fbx file) into 3ds Max and making there the material using the same Photoshop material and rendering...
Alfredo_Medina
Message 2 of 16 (444 Views)
Re: Glass ball/concrete skin
04-16-2013 05:41 AM in reply to: mcfletch2015
What is the pattern or logic, if there is a pattern?
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Active Member
mcfletch2015
Message 3 of 16 (426 Views)
04-16-2013 12:31 PM in reply to: Alfredo_Medina
There isn't a specific pattern or logic. I'm simply trying to accomplish the idea of how glass balls are molded into the concrete that have transmissive and reflective qualities of light.
constantin.stroescu
Message 4 of 16 (408 Views)
04-16-2013 05:35 PM in reply to: mcfletch2015
Constantin Stroescu
BIM Manager AGD
Active Member
mcfletch2015
Message 5 of 16 (399 Views)
04-16-2013 05:54 PM in reply to: constantin.stroescu
I used rhino for the image I sent you but the rendering process with the geometries and the compatibility with revit wasn't working well. This alternative helps a lot. I appreciate your efforts. I will try to do this and see if I get the same results.
constantin.stroescu
Message 6 of 16 (376 Views)
04-16-2013 11:04 PM in reply to: mcfletch2015
I din not work in Rhino , but as I know its files can be imported well in Revit.
I worked with imported 3d dwg objects ( in Families and then loaded in the Project )and they could edited only on material field but, they could be cut in sections...I supose the same happens with rhino files....
Maybe this documentation can help you for exporting to Revit:
 http://www.bimtopia.com/faqs/item/transferring-models-rhino-to-revit-to-rhino.html
http://rhinorevit.wordpress.com/
http://wiki.bk.tudelft.nl/toi-pedia/Rhino_File_Exchange
Constantin Stroescu
BIM Manager AGD
Alfredo_Medina
Message 7 of 16 (360 Views)
04-17-2013 08:13 AM in reply to: constantin.stroescu
This can be done in Revit, too, combining the following features: Divide & Repeat, and adaptive points.
Active Member
mcfletch2015
Message 8 of 16 (340 Views)
04-17-2013 10:21 AM in reply to: Alfredo_Medina
Would you mind elaborating a bit on this method?
Alfredo_Medina
Message 9 of 16 (322 Views)
04-17-2013 03:03 PM in reply to: mcfletch2015
The explanation might be rather long for this format. I suggest you to visit the blog of Zach Kron, software analyst for Autodesk, the name of the blog is Buildz. He has some blog articles dedicated to the topic of Divide & Repeat, in combination to adaptive points.
Active Member
mcfletch2015
Message 10 of 16 (315 Views)
04-17-2013 04:46 PM in reply to: mcfletch2015
Ok great! I will do so.
