Revit Architecture
Revit Architecture
Elmo
Message 11 of 13 (495 Views)
Re: Getting Result=1603 when installing my Revit Deployment
10-29-2009 06:05 AM in reply to: DarkZZZ
Have a look at this link.
[http://support.microsoft.com/kb/834484]
Error 1603 is common to admin or power user rights not being available. Might just be that is what you need to do.
dannyv79
Message 12 of 13 (495 Views)
10-29-2009 06:12 AM in reply to: DarkZZZ
It was in fact the replacement of the "fnp_act_installer_32_bit.zip" that ended up allowing me to install with no issues. From what I read this occurs when installing 2010 after a 2009 install has already been placed on the PC. With that said it does not seem to be the case every time since I have 5 other PC's that I have installed 2010 on. 2 of the 6 PC's needed to have this file placed to be corrected.
Thank you all for the help in getting this resolved.
Active Member
darianklare
Message 13 of 13 (495 Views)
10-29-2009 08:21 AM in reply to: DarkZZZ
Great, glad it worked for you as well!
Kindly,
Darian
