Get access to Revit DB - multi project
1 REPLY 1
arnaudblondel
409 Views, 1 Reply
Hi, We are a general construction company and we are currently using Revit 2015. We aim at making everybody in the company work on the same BIM for the new residences we built (ie : architects, electrical department, HVAC department...) Our goal is to link our Revit projects with our ERP (MS Dynamics NAV, we have inhouse developers for it) so that we can easily import data from the Revit nomenclatures and create purchase orders in the ERP. Example : - the architecture departments creates the project and draw the building - the electrical department adds all switches, plugs, etc. in the same Revit project - the purchase department imports the electrical nomenclatures from Revit in the ERP and creates purchase orders for the switches We tried Revit DB Link, but it suffers really annoying limitations : - triggered manually - we are looking for a real time Revit <-> DB synchro, or at least schedulable - 1 Revit project results in 1 DB (we use SQL Server) - we would like to have 1 DB with all Revit Projects in it, with a Project ID or something like that Thanks to all for your input Regards, Arnaud
1 REPLY 1
I found the following blog post with information on this topic:
http://thebuildingcoder.typepad.com/blog/2009/01/database-integration.html
Are your in-house developers working to create an add-in to provide the desired functionality?
Lance Coffey
Technical Support Specialist
