Generic Family - Room Bounding Propoerties
15 REPLIES 15
Message 1 of 16
11051 Views, 15 Replies
I would like to add a "Room Bounding" Parameter / Constraint to a Generic Family I have already created
I have successfully created a Shear wall Family for the core of a building I am modeling.
 I've stacked one on top of another and linked it as a project file with a Global "Room Bounding" checked into the main Project File
Geometrically it all works perfectly and even looks right with a concrete fill linestyle. But sadly the instance doesn't appear to realise that it is meant to act like a wall when it comes to adding rooms!
15 REPLIES 15
Message 2 of 16
loboarch
Generic families can't be room bounding.  What you could do is create a room seperation line and then aling and lock that to your generic family.  This would make it act like it is room bounding.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 3 of 16
I have tried something and it worked for me. If it is not a problem to change the category of the generic model family, you can make it a WALL, or Column from the "Family Category and Properties" box and reload it into the project. My case was, that I had a "hand-made" chimney, which was generic model extrusion in Mechanical Equipment category. So I turned it to "Column" category, which is room bounding.
Message 4 of 16
Sahay_R
@Anonymous @loboarch - I know this is an old thread.... but here goes.
Architecture>>Component>>Model in place
When prompted, pick a Room Bounding category (Walls or Columns - I prefer Walls)
Insert>>Load Family
Load and insert the desired family. Select it - make it into a Group.
File>>Saveas>>Library>>Group
Save the Group that you just created out as a family.
Now you can edit the desired family, and associate parameters to allow desired control. And yes, this will be Room Bounding, among other things.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 5 of 16
in reply to: Sahay_R
Or you can create a family using Column template.
Message 6 of 16
Sahay_R
in reply to: ToanDN
Very true, @ToanDN. Just be careful that the instances are hosted to the level - otherwise the room won't recognize them.....as a matter of fact, just switching the family category around is also an option.....
Rina Sahay
Message 7 of 16
pieter5
Wow... I knew about this workaround to convert inplace families to regular families but I had no idea it would allow you to create component families for the forbidden categories! Thanks for sharing.
Message 8 of 16
Nisreenki
@Sahay_R  Hello, i know this is an old thread but i am facing the same problem and just saw this work around! when i choose to save as the group the file extension displayed is .rvt so it is saving the group as a project and not as a family, is there another way to save the group as a family ? i am using rvt 2018
Message 9 of 16
Sahay_R
in reply to: Nisreenki
Make sure that you are in Edit In Place. Then select the geometry and make it into a group - and save it out to the RFA.
Rina Sahay
Message 10 of 16
Nisreenki
@Sahay_R  Thank you so much! it worked like magic
I turned the family I want into wall family and got it as room bounding, but there's another solid in the family with visibility settings in one type (the family contains more than one type) that is affecting the room's area calculation, is there a certain setting that I can turn on/off so the solid won't affect the room's boundary or i should just separate the different types?
I attached a small sample
Message 11 of 16
Sahay_R
Separate families is one way out. Or else you can use an if/then statement, where if visibility is yes, then value of area will be area1, if no, it will be area2
Rina Sahay
Message 12 of 16
You could just create a Column Family and set it as Room Boundary. Yes you can model it in any shapes and sizes, not necessary a column.
Message 13 of 16
dm0144
in reply to: loboarch
@loboarch I tried that and it didn't work form me.
Message 14 of 16
RDAOU
in reply to: dm0144
Select room separators + family and create group
Message 15 of 16
Mark_Engwirda
Hi Sahay-R, this is an excellent solution!
I don't know why Autodesk doesn't implement a room bounding option for Revit families such as generic, casement etc.
Maybe this should be on the ideas board?
Message 16 of 16
AWE SOME!
