Generate list
4 REPLIES 4
307 Views, 4 Replies
Generate list
Hallo out there,
Any idea how to generate list of equipments with room name and room number set in linked Revit-model? Is that possible at all?
4 REPLIES 4
Alfredo_Medina
Yes. In the host file, create a schedule of those items, including room parameters, and activating "include elements in linked files".
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
in reply to: Alfredo_Medina
Dear Alfredo thanks a lot for your effort; but I don’t mean the equipments in the linked Revit-Model. May be I've to explain exactly what I meant by generating a list of equipments in linked Revit-model. I want to create just a Revit-file with only equipments and want generate a list of the equipments from my Revit-file and the room names and numbers from my linked Revit model.
I could not create a parameter for the equipments linked to the rooms of the referenced Revit-model. I'll be very glad, if you can give me any hint.
and thanks again!
Alfredo_Medina
Oh, I see...  Sorry for the confusion. What you want to do is not possible, at least, not directly.
Only solution I can think of is this: Select the link > Edit type > Activate room bounding. Then create new rooms. You will need to enter the name and number of the rooms again in those new rooms.
Thank you very much Alfredo anyhow.
