Garage Floor Drain Family
3 REPLIES 3
kate_vanhout
665 Views, 3 Replies
I would like to create a family for our garage floor drain... I would like to be able to place the family on the main/garage level floor plan but I would also like it to show up on the foundation plan, but without putting another family on the foundation plan because I only want 1 garage floor drain to show up in my schedules.  Does anyone have any ideas on how to do this!?
3 REPLIES 3
A family with a vertical invisible line, maybe controlled by a parameter to adjust as per the depth of the foundation, will show the fixture at the level of placement, and also at the lower level, and will report just once in the schedule.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Thanks so much!! 🙂 that work like a charm.  Is there any possible way to make something different show up on the basement? forinstance, We show our garage doors looking like a garage door on the main level, but then just a hatch in the concrete in the basement.  Is there a way to make that work!?
I don't know. Keep in mind that it is the same family, shown in two different levels, so whatever changes you do to the family, will be shown in both levels. If you hide or show anything on the foundation plan, that is going to be shown or hidden in the level above as well.
