FSR Schedule Formula
11 REPLIES 11
Message 1 of 12
tonkata
1807 Views, 11 Replies
Need help in setting up a schedule formula.
What I would like to do is creating A FSR (floor space ration) within my schedule. It's calculated by dividing the gross floor area, by the site area.
Let's say the GFA is 9400m2 / Site Area being 4500m2, this would equal to a FSR of 2.08:1
How would I do this within a schedule?
11 REPLIES 11
Message 2 of 12
in reply to: tonkata
You would need to add a SiteArea parameter in your Area schedule and input your actual Site Area value for it. Since the site most likely never changes for a project, you would not have to do it more than once. The rest is just a calculated value in a schedule. See attached.
Message 3 of 12
tonkata
in reply to: ToanDN
ToanDN, there is no attached?
Message 4 of 12
maciejwypych
1. Add new calculated value in your schedule.
2 In the formula enter Area / n
n- could be your site area, or Site Area project parameter, which is a better idea, because you can refer to it in more schedules.
Maciej
Message 5 of 12
Maybe something is wrong with my browser, I can't attached anything.  You can look at the screenshot from other answer.  My solution is basically the same.
Message 6 of 12
tonkata
in reply to: maciejwypych
Maciej, I must be doing something wrong because I'm getting 0?
Message 7 of 12
Message 8 of 12
tonkata
in reply to: ToanDN
Thank you so much ToanDN, that works perfect.
If on the other hand I had multiple levels, and instead wanted to do a "total" gross floor area / Site Area, what would I need to add to this formula to make this work?
Message 9 of 12
maciejwypych
Hi Tonkata,
I'm guessing that your area format is set to 0 decimal places, you need to change the Rounding in Formatting>Field Format... to 2 or (however many you like) decimal places.
For more levels, again in Formatting select FSR and check Calculate totals.
Maciej
Message 10 of 12
+1 to what Maciej said.
You can check out the multiple level sample here.
Message 11 of 12
tonkata
in reply to: ToanDN
Maciej, I've activated the 2 decimal place for FSR, however even with totals on, the FSR doesn't adjust?
Message 12 of 12
maciejwypych
Tonkata,
If you are using Site Area parameter, it is an instance parameter, and you need to populate each field in the schedule. (Otherwise, Revit tries to divide by 0 and it doesn't work, so the FSR values are empty 🙂 )
Just click on the remaining fields and type in the Site Area value, or select the areas one by one and type in the Site Area value in the properties.
Or you can skip the Site Area parameter and in the FSR put Area / 4160m²
Maciej
