Hi. I just installed Revit Architecture 2011. I didn't get any errors during installation. If I run it, the splash screen appears followed by the error that it might not support my videocard followed by the "Recent Files" screen where I can select a basic/advanced sample project or a basic/advanced sample family. This is as far as it loads. If I click New or try to open an existing file, it freezes (I already have a project even though I've never run Revit at thome because I created the project at school). It also won't run in safemode. According to the knowledge base, it might "be a conflict with the ArchVision Content Manager Location."
Solved by ryan.duell. Go to Solution.
I would test the following 3 items:
1. Verify it is not the TS below:
Revit 2011 Hangs at Splash Screen or Crashes with Unrecoverable Error
2. Apply web update 2 service pack prior to launching from the link below:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=14973244
3. If the issue persists, and you would like to edit the Revit.ini the lines should go in the following default location:
[Selection]
AllowPressAndDrag=1
[ContentUpdated_SP1]
Updated=1
[UserInterface]
DisplayRecentFilesPage=1
[AppFrame]
Theme=1
[ACMSettings]
ACMOnNetwork=1
ACMNetworkPort=14931
[CommonDialog]
Please let us know if this was helpful.
Thank you,
When I downloaded and installed it, I didn't see the configure button in the installation screen. I installed it again and saw the configure button so I clicked it and saw there was a patch to download. So it works now. Thanks.
