Is the Freeze drawings extension available for 2014?
Solved by derrickmoore. Go to Solution.
I am not familiar with this... Can you explain a bit more - where did you get it before?
LD
Thank you for your post. In this case are you looking for the RoboBat tool that was created a few years back with the Robobat software? This is the only other software I have seen this reference previously. Please clarify so we can best assist in this post where applicable. Thank you and we look forward to your reply.
Robobat Link: http://www.autodesk.com/products/autodesk-simulation-family/features/robot-structural-analysis
The last time I saw it as an extension was in Revit Architecture 2012. I think now you will just have to export a view as a dwg and then insert it back into the model's drafting view. I realize the freeze drawing extension handled the entire process previously. I have not seen a replacement for that feature. One may exist I just have not seen it.
It's part of the Revit Extensions from the subscription site but it's a terrible tool - from what I understand it explodes dwg files
