I wanted to export direct to 3D rendering programs so created this Revit to OBJ converter. It is based on the Revit 2014 API new export code so only works with Revit 2014.
Materials are exported with colour and transparency and I've added the option to create a material texture file xml list to export textures. It is currently not possible to get this information from the Revit API.
It's been tested with Blender, Octane Render and 3ds Max Design 2014.
If anyone wants it - look on http:\\www.inglegreen.com
hi
For export Revit file to 3d max FBX format is the best choice in my opinion.
Absolutely, but several of the rendering softwares use OBJ as their (only) input format. If 3ds Max isn't available or is too intimidating for converting on to OBJ then my Addin may be useful ...
There is a new version 1.3 of the Revit to OBJ Converter.
I have provided the choice to export by Revit ID (grouped meshes) or as previously by individual meshes.
Thanks for this converter. I just tried the current version for Revit 2015. The OBJ output worked well in Metaio Creator (augmented reality app).
Thanks for the feedback. I am pleased the converter is proving useful ...
The latest version includes the option to export just the elements that have been selected. This makes it easy to add newly created Revit elements or to replace elements that have been updated in Revit.
Hi Jawad
This is a Visual C# plugin.
I have uploaded v1.8.2 to my site that adds the options to use either 'o' or 'g' for the Object definition.
I realise Unity makes things a little more complicated. By all means drop me an email with your ideas ...
As there are now many settings for the plugin - a new version 1.8.3 saves settings to an XML file stored with the plugin. Let me know if there are any problems with this ...
Hi Guys,
I would like to ask how to setup the Revit OBJ export? I tried to follow the instructions given from the downloable installation but it does not appear in Revit Add In portion. Kindly advise and thanks
nstall RevitOBJExport.addin and RevitOBJExport.dll to the Revit Addins directory.
Example directory paths are :-
C:\ProgramData\Autodesk\Revit\Addins\2015\
C:\Users\<user>\AppData\Roaming\Autodesk\Revit\Addins\2015\
either location will be ok ...
Regards
Hi
Ideas :-
1. You may need to select 'show hidden files, folders and drives' in the Windows Explorer 'Folder 'View' Options' in order to see the correct directory.
2. Scan for the directories that include in their name - 'Autodesk\Revit\Addins\2015' or if you have Revit 2014 - 'Autodesk\Revit\Addins\2014' to find a valid location.
Regards
Clive
I get
"Revit cannot run the external application 'RevitOBJExport2". Contact the provider for assistance. Information they provided to Revit about their identity: Inglegreen.com-Tech-22"
in both 2016 and 2017.
Thanks!
Hi Tony,
Yoy may need to unblock the .addin and .dll on the properties. Do that on both files and it should be ok.
I also got an error message when trying to run the 2017 version (and I did "Unblock" the .dll after downloading).
That docs specify that it was compiled using .net 4.5.2, but it should be compiled using 4.6.
you can use free ArtisGL Exporter add-on
https://apps.autodesk.com/RVT/en/Detail/Index?id=2282307907884501673&appLang=en&os=Win64
It allows to export any Revit project to obj, but also export your project to ArtisGL 3D Publisher and publish project to the web by using WebGL technology
https://www.youtube.com/watch?v=udeG4O1vUW8&t=150s
Can you pls share the plug-in tool for 2014 with me?
I visited the website you provide and I can not find it anymore.
If you have 3ds max, you can import Revit model in there and then export it as OBJ. I avoid plugin because as soon as there is new version, it won't be supported or it is no longer exist.
Hi, have you tryed https://apps.autodesk.com/RVT/en/Detail/Index?id=2282307907884501673&appLang=en&os=Win64
it should work well with 2014
