Good morning, I am having an issue the structural framing on my models. I use both Revit Building and Revit Structure, however this issue seems to apply to both packages. My problem has to do with the framing members automatically joining to each other. I design modular buildings, which are a series of steel frames that are placed next to each other to form a complete building. I have created the various frame pieces (Roofs & Floors) and then inserted them as groups into a model. When I create a single complete frame (Floor frame, Columns @ corners & Roof frame) it appears to be graphically correct and all of the framing pieces join properly. Once I start to copy the additional frames throughout my model I start having problems with the framing. Where the modules meet each other the framing starts applying end offsets and joins with the wrong framing. Admittedly I am not adding the framing in a way that Revit wants me to. Most of the shapes are custom cold-rolled shapes that I have created, also many of the connections need to be modeled accurately because they are often exposed, also the documentation needs to be presented in a way that is familiar to our production crews. In order to present the model properly I need to cope many of the members so that they fit together correctly. I have supplied some screen captures (I apologize for the poor quality) that graphically describe the problem. I think I have two solutions, the first would be to disallow framing joins, however I don't know if that is possible. The second would be to recreate all of the structural framing items as generic components not structural components. I would prefer not to use generic components if possible, but I will if I have no other option. I would greatly appreciate any insight or assistance that you have. Thank you in advance for your assistance.
