Foundation for Stacked Wall
8 REPLIES 8
Message 1 of 9
PhilvK
572 Views, 8 Replies
Below in black is a stacked wall with stucco on 8” cmu above brick on 8” cmu. One way to support this wall would be to let the wall rest on a thickened edge as shown by the green lines on sketch #1. The second way would be to extend the cmu down to the footing as shown by the red lines on sketch #2. My question is: is there way to have the cmu extend within the stacked wall type, or does another short cmu foundation wall need to be added under the stacked wall if we go this way?
Phil
8 REPLIES 8
Message 2 of 9
L.Maas
in reply to: PhilvK
Would this be a solution for you?
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 9
GHASEM_ARIYANI
in reply to: PhilvK
HI
Solution # 1
After drawing floor ، Select tool Slab Floor Edge.
Click the On the edge of the floor
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
Message 4 of 9
PhilvK
in reply to: L.Maas
Yes, thanks. Something like this is what I was heading for after I viewed more videos after my original post. I need to look at your solution a little more closer to understand where your stacked components start and end. Thanks again!
Message 5 of 9
PhilvK
in reply to: GHASEM_ARIYANI
Thank you!
Message 6 of 9
L.Maas
in reply to: PhilvK
Hereby the project with wall
Louis
Message 7 of 9
PhilvK
in reply to: L.Maas
Perfect! Thank you very much.
Message 8 of 9
PhilvK
in reply to: L.Maas
One question on the footing part of the stacked wall. I see you created this as a wall type, correct? Is this the same as selecting Structure>Foundation>Wall from the menu?
Message 9 of 9
L.Maas
in reply to: PhilvK
In general it should be about the same. The way you proposed it are two separate objects. So you have a little bit more flexibility. On the other hand you would have to do more actions. So I would say little bit more flexibility or a little bit faster work. Maybe there are some other small nuances like easier scheduling. As often in Revit...there are several ways to get to the same end result.
Louis
