I am trying to change the body text in a schedule. Autodesk Revit help says to “select a text type from the Body text list. You can create a new text type if needed”. How do you create a new text type? When I select the body text, the Font button on the ribbon is grayed out.
Solved by SteveKStafford. Go to Solution.
Annotation ribbon > Text panel > click the small diagonal arrow button (Text Types) in the bottom right corner of the panel. That opens the Text Properties dialog and you can create a new text type here, via the Duplicate button.
