font difference between AutoCAD and Revit
4 REPLIES 4
816 Views, 4 Replies
We are trying to replicate our current autocad titleblock in Revit
The font in Autocad is Arial with a width factor 1.
But when I use what I think is the same arial font in Revit the total width of a word or string of words is slightly longer in Revit then AutoCAD.
Does autocad do something different to the font than Revit does?
Any thoughs
4 REPLIES 4
Mr Spot
Hmm, I'd just tried adjusting the width factor in revit until you get a close match...
I assume you are talking about R8 - what about R7?
width factor upon import was just introduced in r8. There is no width
factor in r7 of Revit.
wrote in message news:4836840@discussion.autodesk.com...
I think something is awry, perhaps the intended scale of the text height is different than the scale of the view you are importing to? I have the same width when I try it...see attached image.
