Floor slab editing in phases
2 REPLIES 2
parveensharma2130
1171 Views, 2 Replies
Can we demolish a small part of existing slab.
(We can divide the slab in two parts and demolish one part. But then we will see another lines in existing phase).
We can hide those lines in existing floor plan.
But is there a better way to do it.
Parveen Sharma
2 REPLIES 2
You're already doing what I was going to suggest. We use separate floors, each with its own phasing properties. The linework tool has become my new best friend...
Please post a better solution if you come up with something.
- Alex
I shall post an update on new solution for this problem.
Since We say that Revit is like "Virtual Construction", It should behave like real life (We should be able to demolish a part of existing floor).
Though I am o.k. with the current arrangement (using linework tool). 🙂
