Floor Finishes not showing up
2 REPLIES 2
5914 Views, 2 Replies
Hi
I have a file that I have applied different floor finishes to different rooms based on flooring patterns and hatches - they are not visible in the floor plans . Funny thing is if I make a seperate room outside the project in the same view and assign it flooring patterns - it does show up all the floor finishes. The only reason I can think of is phases. Please help.  I have attached images for reference.
2 REPLIES 2
Jason_S
Are you using floors to show the finishes or patterns on the floor?  If so remember floors don't go above the level line unless you specify a positive offset in the properties palette so the floor finishes are above the concrete or rough floor.
I had the same happen to me. The finishes showed up in all views but the floor plan. Tried several things but finally I turned off the analytical properties of the foundation and like magic, they appeared.
