Hi
I have a file that I have applied different floor finishes to different rooms based on flooring patterns and hatches - they are not visible in the floor plans . Funny thing is if I make a seperate room outside the project in the same view and assign it flooring patterns - it does show up all the floor finishes. The only reason I can think of is phases. Please help. I have attached images for reference.
Are you using floors to show the finishes or patterns on the floor? If so remember floors don't go above the level line unless you specify a positive offset in the properties palette so the floor finishes are above the concrete or rough floor.
I had the same happen to me. The finishes showed up in all views but the floor plan. Tried several things but finally I turned off the analytical properties of the foundation and like magic, they appeared.
