Alfredo,
Just setting up our template with a material legend, thanks for posting your explanation, was very helpful. The Revit help states that typical legends include
"Materials Legend. Displays a sample of a cut or surface pattern and text identifying the material associated with that pattern."
but then fails to elaborate how to achieve one!
Alfredo's tutorial was incredibly helpful.
The only thing i would add is between steps 3 and 4.
'Manage' Tab -> 'Transfer Project Standards' -> 'Copy from' Choose current project file -> 'Fill Patterns'
This just allows you to use the materials from your current project. Then if you decide to alter the material appearance in your project, the legend item updates as well.
Hi, and thank you for the helpful explanation. A question for Autodesk : how is it possible that 13 years later, there is still no tool to create a plan for floor finishes ?!? It's soooooo basic, and the prices of the licenses are still going up
A strategy I've developed over the years for things like doors, windows, floor legends, etc is to utilize an abstract Design Option at Sea Level. I create an option set called "Z-Standards". The primary option is called <empty>. Nothing goes in that primary option. This will ensure it will never be seen or scheduled accidently in the project. Then, I will create a new option for "Walls", "Floors", "Doors", etc and draw a 4x4 section of each type that needs to display in a legend. You can then create any view type you need and set that particular view to that specific option. Apply the same view template to that particular abstract view and any changes you make to those patterns over time will be accurately reflected in this new view. No filled regions or other gymnastics required. Regardless if it is a material or a filter, it will show up just as intended. The added benefit of this method is you can also use your typical tags as well.
I've seen this done using phases as well, but I find introducing a "standards" phase can cause problems if users don't pay attention.
Hah we share the exact same approach.
@randy_lmn ,
it seems like a "not too bad option", except that you can't place the view on every sheet since it's not a legend.
Thanks anyway for the tips !
I've used "duplicate as dependent" for situations that need to be on multiple sheets, but typically these are views that usually only appear on one sheet anyway. i.e. the graphic door legend is not on every plan or elevation sheet, but rather just on the door schedule sheet.
