Revit Architecture
Active Contributor
jason_spiller
Message 1 of 6 (202 Views)
Floor Boundary affected by spiral stair
202 Views, 5 Replies
04-03-2014 05:18 AM
Hi
I have created a spiral staircase and want to add a floor at the top level - straight forward, but the profile and the generated floor do not correspond. I am assuming the stair is autocutting the floor - how can I stop/adjust this?
Thanks in advance.
Solved it!
There was a cylinder surrounding the staircase acting as the cutter - I adjusted its height and got the fix - thanks for your input :smileyhappy:
arunag
Message 2 of 6 (180 Views)
Re: Floor Boundary affected by spiral stair
04-03-2014 07:12 AM in reply to: jason_spiller
Check if it got attached to roof at another level, Stairs don't autocut floors..
Aruna
SOA,MSRIT,Bangalore
Active Contributor
jason_spiller
Message 3 of 6 (176 Views)
04-03-2014 07:31 AM in reply to: arunag
Hi
The floor is not connected to a roof - in fact it isn't connected to
anything at the moment.
arunag
Message 4 of 6 (124 Views)
04-06-2014 10:21 AM in reply to: jason_spiller
Check the sectional 3D view to see if the floor is indeed auto cutting the stairs...Also check if any height offset parameter was input in the floor..
Aruna
SOA,MSRIT,Bangalore
Active Contributor
jason_spiller
Message 5 of 6 (108 Views)
04-07-2014 03:40 AM in reply to: arunag
It's definitely the staircase that is cutting the floor causing it to ignore its profile - if I move the floor out of range ogf the staircase the profile is applied, now I'm really confused?!
Active Contributor
jason_spiller
Message 6 of 6 (104 Views)
04-07-2014 04:16 AM in reply to: jason_spiller
Solved it!
