Floor based plumbing fixture
1 REPLY 1
395 Views, 1 Reply
Is there a template for this ? -- mvh Roger Helgesen Helgesen Tekniske-bygg AS roger@ht-gruppen.no 56193410 / 93463588
1 REPLY 1
Roger Helgesen wrote: > Is there a template for this ? > Yes and no. If you don't have a template for what you want, you can always start with a generic template and then under Family Categories on the settings bar change it to be in the desired Category. It's quite flexible, actually. So start with the 'floor hosted Generic Family' template, and then model/draw/whatever your floor-mount plumbing fixture, then set it's category to 'Plumbing Fixture' and save it out to your library. Revit will make it behave as both a floor hosted element and a plumbing fixture when it's loaded into a project. hope this helps! -- Jeffrey McGrew Application Specialist BSD AEC Technologies, a division of ID8 Media Inc. (415) 593-6000 x 129 (415) 593-3333 Fax (415) 505-4689 Cell www.aectech.com www.id8media.com
