Floating objects
2 REPLIES 2
cjp
1393 Views, 2 Replies
Floating objects
I have modeled up a mudroom/kitchen in Revit. In my rendering it seems as if nothing is touching anything else. The walls seem to float and the cabinet piece that I modeled looks to have gaps between the sides and the wall. In plan it fits perfectly in the space as that is the size I modeled it at. I had taken an ootb base cabinet and manipulated it (to the extreme) to make this cabinet piece that fits in the space. At one time I had even moved the side walls in to overlap the cabinet a little to see if that helped the problem, but it didnt. I am thinking this is beyond just an optical illusion. I have attached the rendered photo and maybe someone has an idea on how to overcome this floating look. Thanks in advance.
2 REPLIES 2
fernanda.firman
in reply to: cjp
Hi, It does seems like it is an optical ilusion created by the lighting.
In the rvt file, please cut a section through the walls and cabinet. Do you see them floating?
Try changing the material of the floor and walls to see if the result is different.
Can you post a sample file so I can try rendering on my end?
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
cjp
in reply to: fernanda.firman
The section checks out and nothing is floating. I have even overlapped some things i.e made the wall offset deeper into the floor etc. I applied a different material to the walls and had no luck. I may try some other materials later. My revit file is huge as it is the whole house. I do not know if theres a way to send just a portion of it. I suppose I could copy and paste that section of the house into a new file, but I am afraid it may not give the same result as something somewhere may have an effect on it, or maybe I am just paranoid.
-C.Rash
