Alright, I made a custom bookshelf to fit under my stairs, however, when I created them, I made them on a horizontal plane, so when I loaded into my project, my book shelf is laying down in the middle of the living room floor, which was fun at first, but nearly an hour later I am not so amused. Is there a way to flip it vertically or do I have to remake the whole bookshelf?
R.R.
Solved by scott_d_davis. Go to Solution.
problem is that "implied" constraints were made between the bookshelf you made and the horizontal gorund plane. When you made these objects, they were built off a certain plane, and there is not an easy way ot assign them to a new work plane.
Sorry to say, but it's time to start rebuilding...chalk it up to lessons learned?
if you have used Generic Model Face Based as a template , perhaps you had now no problems to insert your object in the project...even if you want to place it on the slope of the roof...
Constantin Stroescu
I have to turn in a prelab in the morning...I am really confused and I am afraid this is super easy but I am making it harder than it is! At this point, I have scrapped everything and I am lost.
Calculate the electric field strength in the region between the two voltage probes of the following configuration.
