I have a linked structural file in my project. When I create a horizontal section to show the plan at the front of the building, the column bubbles are on the wrong side (outside) instead of inside the building where I prefer them (dimensions are going outside). Is it possible to flip the side of the column grid that the bubbles appear, on a per view basis? I'm not sure how to do this with a linked file. Also, is there a parameter that controls how far the grid extends beyond the crop or annotation crop boundary?
Jon
As I recall, I do not think you can control / flip the grid bubbles of a linked file. You can Tab and highlight the grid lines in a linked model, but I don't think the controls are available? ( don't have Revit open .)
A Scope Box can be used to control locations of the grid bubbles and also Level Heads.
cheers
