Flexing a blend above a column
5 REPLIES 5
OZRevit
482 Views, 5 Replies
Made a concrete column family and a blend to go on top of the column (as a seperate family).
All works fine (in terms of flexing) except that when I flex the column, it goes right through the blend above it!
How do I get the column to flex (Up or down) so that the blend above it also moves?
Thanks in advance
5 REPLIES 5
alan.quinn
in reply to: OZRevit
Align and lock the blend to the top of the column. See attached image.
Hope this helps,
OZRevit
Thanks for the reply, I did align and lock the blend to the top of the column, when I flex the column, I get "Constraints are not satisfied"
I attached the file, please advise.
Many thanks
alan.quinn
See the attached file. I added the blend to your column.
Hope this helps.
OZRevit
Thanks for your help Alan.
This is not the file I sent you though...how do I fix the problem in my file?
alan.quinn
You have to align and lock the bottom edge of the blend to the Top Ref Plane. See the attached.
Thank you,
Rail Community
