<PamWhitehead2484> wrote in messageHas
href="news:6196710@discussion.autodesk.com">news:6196710@discussion.autodesk.com...
anyone created a residential project in Revit with flat roofs or parapets?
We're working on a modern house and the program will not seem to allow us to
create a flat roof or a parapet condition. Has Revit missed allowing this
option in residential projects? We also have a similar problem when drawing
interiors. We cannot figure out a way to draw a soffit condition within the
building. Has anyone found a way to draw a soffit in the Ceiling commands? We
have lots of conditions with floating planes of ceilings cantilevering from
walls on the inside of our design that need to be rendered.
Thanks!
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
Thanks!
I am a Revit amateur my challenges is how to great a parapet on my building, please I will Appreciate if you can help me.
Create a floor plan referencing the Roof level
Views>>Plan Views>>Floor Plan
Go to that view. Use a regular wall but keep the height lower. You should be OK.
Thank you so much for your replied. Like I have said earlier I am a Revit amateur please I will be please, If you tell me how to furnish my interior design
Are you talking about adding furniture to your building? In that case, you can add furniture from the Furniture Library. To add -
Insert>>Load Family
Once the family is loaded, go to
Architecture>>Component
to drop it in
If the OOTB library does not have the kind of furniture that you need, then go to the BIMObjects website. You will be able to find manufacturer content from there.
@Anonymous wrote:
In order to create the roof and define its slope, you need to select the outside face of the exterior walls. So the flat roof extends to this outside face of the wall. What this creates in elevations and the 3D drawing is a line showing the thickness of the flat roof. We don't want to see this roof thickness rendered. And we also have conditions where the exterior walls are taller than the roof itself. How do you render the walls as being taller (parapet conditions) with a roof that has a minimal slope?
Thanks!
1. No, no, you don't need to select exterior faces of walls in order to create a roof. Not at all. You can create a roof without any other elements existing in the model at all. You pick a LEVEL to associate the roof with (which is done by default if you draw the roof in a floor plan view, because the floor plan view is associated with a level already) and then you sketch it's footprint. Now you CAN sketch it by selecting walls, but you can also use any of the drawing tools available. So you can define the edge of the roof along exterior wall face, along interior wall faces, or wherever you want.
2. Walls have a couple of important parameters call Top Constraint and Top Offset. The Top Constraint usually defaults to the next higher Level, and the Top Offset defaults to 0'-0". If you have walls up to Level 2, and you built your roof on Level 2 also, then give the walls a value in the Top Offset parameter to raise the tops of them up higher then the edge of the roof.
3. If your Revit guy doesn't understand these very basic concepts yet, send him to a beginner class, or at least have him spend thirty minutes watching youtube videos.
Create a wall
Architecture>>Wall
Go to a 3D view
Architecture>>Curtain Grid
This will allow you to set up a grid. Then
Architecture>>Mullion
This will allow you to assign mullions to the curtain wall
