Flat Roof Structure Section Issue
1 REPLY 1
alex60
396 Views, 1 Reply
Hi all, this is the first time that I realize this issue in Revit. I was making a new roof with a thickness of 1'-0" and a finish of 3/4" , but after I made the roof, the roof structure shows up 10" and the finish.  See the attached images. However, when I make a hip roof with the same type of roof, the section is correct. Does anyone have this experience? and tell me if this is a bug of Revit.
Thanks in advance, Alex
1 REPLY 1
alex60
in reply to: alex60
Hi all, this  post to confirm that Revit 2015 has the same issue that 2013. I made a roof with several layers and did not represented the thickness well, only put 10", but when you put slopes, then it works fine. Has any one seen this issue?
thanks in advance, Alex
