Revit Architecture
Revit Architecture
Active Contributor
rlabib
Message 1 of 2 (134 Views)
Fixtures and doors barely show in demo ? ( line weight)
134 Views, 1 Replies
01-23-2013 05:54 AM
I'm working on a project where 80% of the building is being demolished . I have setup two phases Existing and New, in the existing phase , I applied a phase filter to show the demolished and the components to remain on site. All demolished items show as dashed. I have a problem with the door swing line weight  and the fixtures line weight. when I print the demolition plan everything prints ok except the door swing and the fixtures, the barely show? any ideas , I tried GV ( graphic override) , it didn't work?
Active Contributor
rlabib
Message 2 of 2 (122 Views)
Re: Fixtures and doors barely show in demo ? ( line weight)
01-23-2013 08:05 AM in reply to: rlabib
Never Mind , I played with the Graphic overrides in the phases dialog box , and when I changed the temporary to a different color and lineweight , the door and the fixtures appearance changed. At first I assumed everything changes when I change the Demolition appearance .
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
